Sign in to follow this
tiago3008
Composite
always review the out file for warnings and errors:
Quote
 *** ERROR # 772 ***
 It is invalid to use a free grid as an independent grid in RBE3 data.
 Free spiders are not allowed to be independent grids in RBE3 data.
                RBE3 id =     5082
           free grid id =        2
    weighted components =      123
 You should remove this grid from the RBE3 data.
Use Tools>model checker>Optistruct to find modeling errors & warnings and apply autocorrection. Or use Check Elems Panel (F10)>1D>free 1d nodes.
Tp desenho casca-edit.hm
Thank you.
Others two questions:
1- I want do simulate a bidirectional, how i simulate that? If i put E1 and E2 equal, means that it is bidirectional?
2- I also want simulate the resin between the plys. I consider it is MAT1?
