Agonzalez
Work with H3D files
I am triying to work with H3D files, but I don't undertand somethings. I have some matrices that I want to put into a H3D file to use later in Fenfat. I have used this comands and the black parts are that ones I don't know how to used:
1) fid01 = createh3dfile('C:/Users/Base_A/000_Compose/Result_06.h3d');
2) createh3ddatatype(fid01, 'DT scalar elem:nolayer nocorner', 'scalar', 'elem', 0, 0);
3) createh3dsubcase(fid01, 'Subcase_61M', {'SC1 Iteration 1'})
4) writeh3ddata(fid01, 'Subcase_61M', 1, 'char', 0, 0, Elem_ID, y61M2);
5) closeh3dfile(fid01);
Elemn_ID and y61M2 are two matricess column with the same dimensions --> [100000x1]
% fid_ID = createh3dfile(filename)
% createh3ddatatype(fid_ID, label, format, bind[, hasLayers, hasCorners])
% writeh3ddata(fid_ID, subcase, simulation, datatype, layer, corners, entities, data)
% closeh3dfile(fid_ID)
Any one know how to used this comnads?? The explain in the web doesn't help me.
Thank you guys!!!
Alex
Alex, hello!
Please find attached an example with the script and a few files for you to try out.
First of all, please keep in mind that the model information is not inside this new .h3d file, therefore you need to open a model file and the created results file in HyperView if you need to visualize it.
There are 2 opening modes that might be used: new and append:
- new clears the .h3d file for writing
- append adds new information but it cannot modify existing information, which means means that it is not possible to add datatypes, layers or values to an existing subcase
The hierarchy that must be followed is this one:
- Layer definition (if needed)
- Datatype definition (needs the layer in case there is one)
- Subcase definition (needs the datatype)
- Data per se (needs the subcase, datatype and layer in case there is one)
Roberta
simple_only_results.h3dsimple_model.h3dsimple_only_results.oml
llyle likes this
