Ushay
replacing the node
Hello all,
I am creating a beam element connected between two nodal rigid bodies with the line
*createspotweld $x $y 0 0 0 0 0 ""
Where x and y are the independent nodes of 1st and 2nd NRB respectively. When I look into file for generated beam element in the *ELEMENT_BEAM card (LS-Dyna), the 3rd node for the beam element is assigned with a random node id (but same coordinates as first node). Is there any possibility to replace the 3rd node id with the 1st node id?
Hello @Ushay
I think you can create beam with "*barelementcreatewithoffsets" command.
*createvector 1 1 0 0
*barelementcreatewithoffsets Node1 Node2 1 Node3 1 0 0 "" 0 0 0 0 0 0 0 0
Thanks,
Imoto
On 10/21/2019 at 10:35 AM, Imoto said:
Hello @Ushay
Thanks,
Imoto
Hello @Imoto,
thanks for the reply.
It is not accepting the Node 1 and Node 3 to be the same.
I am trying to make the nodes 1 and 3 the same, to get something like this for a beam element.
Thanks
