mpvnaresh
Displacements in a DTRAN Solution
Hi all
 In a Direct Transient solution i have given a acceleration load with certain frequency and amplitude.
When  icheck displacements in the location where acceleration is applied, The Displacement curve is a not oscillationg one.Instead it is keep on going.
Can any one help me in getting the oscillating displacements.
I have tried by changing all options of FORM(1) in Displacement output request.but no use.
Please help me in this .
Sir
with displacements as input load it is oscillating .But the question remains same.
If i convert it into displacements obviously it oscilates as we are giving displacement directly.
But my load case is in acceleration i need to apply it in accelerations only.
Could you please consider initial velocity for the base setup where you have time Vs accel.Transient initial conditions are defined using a TIC Bulk Data Entry. Initial displacements and initial velocities can be defined. This should help you to avoid drift in the displacement plot and get oscillating plot.
Sir
I am not able to give Input of Initial conditions . Can you please help in how to do this?
How to create TIC Bulk data entry. And also i have no data for initial displacements and initial velocities then how to get those values.
Sir
I really Appreciate this.
Thanks a lot for your time.
I think this is solved.
But when try to integrate the acceleration curve to get celocity i am gettion a Zero velocity. Please help me in the methodology for getting velocity.and also how did you created TIC (V).
When i go go to load type page Velocity type is Blank.
Thanks again for the support sir.
TIC V you can create from constraints panel & set the load type to TIC V.Sorry i cant provide you right now the hand calculation which we did to calculate Intial velocity,  as i am away from office desk.However,I do have the math we performed in HyperGraph to crosscheck.PFA mvw file for same,
Ganesh Accel to Intial velocity.mvw
Sir
I calculated Initial Velocity and applied as TIC(V).
But after the compltio of acceleration cycle displacements are cumulative.
(which mathematically  may true, As Acceleration=0,  Velocity which is integral of Acceleration = constant , Then Displacement is a straight line which is cumulative )
How can we make the  velocity, displacement to be zero after the load (Acceleration)is removed .
