AAU
How to enable surface prediction
Hello to everyone:
I have been trying to make predictions with WinProp on walls. The thing is that according to the manual, the database objects should be somehow configured in order to be able to make surface predictions in an indoor scenario. I have tried to do so, but the option is impossible to enable. I have tried in WallMan in Object Tab, surface prediction but I cannot use any of the options provided. Is there anyone who could help me out?
Thank you so much for your attention in advance.
In ProMan, under one of the tabs of Project / Edit Project Parameter, you define a prediction plane: a horizontal rectangle at a certain height, by default at z=1.5 m. So you don't need to do anything special in WallMan.
To create an additional non-standard prediction plane in WallMan, see the answer at topic 36975:
AAU likes this
