Pandurang
Mesh Match For Contact Creation
HI All
I want to create match mesh between 2 Component (but matching surface having different area) for contact creation
i writing the script for this one.
Step i have done till now:
1. create mesh on one surface .
2  project mesh.
3. trim the surface (if one surface is small than other) using outside nodes
4. then create 2D tria  Mesh for remaining surface after trimming : But the problem is mesh connectivity
how to overcome this issue?
Any idea
@Imoto
@tinh
@Manjunath Dasar
@vipin
Thanks
PD
1)
2)
3)
4)
5) Find edges on elems created in 4) and nearby contact area
6) delete a layer of elems that attached to edges found in 5)
7 )use ruled mesh to connect contact elems with remained mesh
