young
NLADAPT DIRECT=yes is not used in my case ?
Hi,everybody,
    I need to fix time increment in my load step , have set NLADAPT>DIRECT>YES,and referece this load  in my loadstep. But the solver seems to ignore it and keeps increasing the incerement size.Can somebody give me an advice on what I could do to solve this issue? Thank you very much!
image.png.88b987160432193c23e2e48cd693b6f6.pngimage.png.1758196dcd50ca8353325d44773bedf6.pngimage.png.466fa66d6fb29329e9ade7bf469b17b0.png
On 10/24/2019 at 6:46 AM, young said:
hi cfuser,my NLparm entry likes this, image.png.1697760998fff3026b70f7672f1026b2.png
Hi Young,
It's weird. I ran a non linear static simulation (frictional contact model). I used this configuration (for NLADAPT,  NLOUT and NLPARM respectively)
image.png.21524420b13f2d1bc21c6b7eb3266411.pngimage.png.55b0e8a70bbf6a74291d3effe7a0e176.pngimage.png.2cc1f93a85ca9b781bc9c1e7912832ab.png
and It worked well ...
If it's not confidential, can you please share your model or verify the time increment story in simple model than you can share it ?
Best regards,
Edited by Farouk Maaboudallah
Tabulation problem
On 10/26/2019 at 3:27 AM, Farouk Maaboudallah said:
To be sure : I repeated the same simulation. Instead of using 0.1 I used 0.05 and it worked well ...
Please keep me in touch.
    Thank you for your reply, I tried the configuration as you said, but it  not works very well,still keeps increasing the incerement size.I try a simple case likes this:
aa.fem
1 hour ago, Hyperman said:
Increment adjustment is automatic by default PARAM>EXPERTNL>AUTO. Try with PARAM>EXPERTNL>NO instead.
Hi,hyperman,
       I have tried this setting as you said,it worked well, the increment size is fixed.Thank you very much.
     But, in other case ,I haven't keep expernel>no, just be sure the DTmax equals to DTmin, the increment can be fixed, so 8s this setting( PARAM>EXPERTNL>NO) only necessary in some cases?
       Looking forward your reply.
12 hours ago, Hyperman said:
The increment can be fixed using either:
  • DTmax=DTmin
  • PARAM>EXPERTNL>NO
However NLADAPT>DIRECT>YES does not work for some reason.
