Sign in to follow this
AAU
Time-variant simulation
Hello to everyone:
I am trying to simulate a time-variant scenario in WinProp. I configure in WallMan firstly the object trajectory.
Then I save the database and I try to load it for simulation in WinProp as a 3D time-variant scenario but I cannot get this option when I load it:
The Simulation Parameters tab just does not appear.
after having defined the time-variant vector database (.idb file) in WallMan you can also check using the "time control" panel if the time-variant objects are moving as expected.
Then you define a new propagation study in ProMan and select the "time-variant scenarios" and the corresponding .idb file. Under "Project => Edit parameters" Simulation tab then the field to define start time, end time and interval should be available.
Generally we recommend to use the latest version of WinProp which is 2019.2.
Okay, thank you so much. The thing is that the position is not changing when checking that so I must have configured something poorly.
