joseamirandavelez
Temporary nodes showing up in pictures
I am making a big macro that basically hides and shows different FE models and geometries, re-orients the view, and take pictures. Since my models are cylindrical, I am taking square images by moving the model to the left side of the graphic window and saving only half of the window using hm_windowtofile. In order to move the model to the left I create some grids at certain distances from the model so that when I fit the view the model is put on the left, then I delete the temporary nodes. That's the only work around I found. My problem is that even after deleting the temporary nodes they appear in the photos. I even tried adding *nodecleartempmark to the beginning of my takePhoto procedure, but they still show. Sometimes I get stiff that is masked in the photo... If I run the macro line by line it works perfectly. It only happens when I run the macro from the script toolbar or menu. So I guess this must have to be some sort of screen update command I am missing. I tried to find any commands to update the screen in the API documentation but had no luck. Any ideas?
Here is a shorter version of my macro:
package require Img
catch {namespace delete ::miranda }
namespace eval ::miranda {
proc ::miranda::main {} {
    #photos are going to be stored here. Folder is created if it does not exist.
    set ::miranda::path "D:/model_images"
    catch {file mkdir $::miranda::path}
    catch {file attributes $::miranda::path -system}
    proc ::miranda::frontView {} {
        #get bound box for whole model
        *createmark elems 1 displayed
        set string [hm_getboundingbox elems 1 0 0 0]
        set xmin [lindex $string 0]
        set xmax [lindex $string 3]
        set ymin [lindex $string 1]
        set ymax [lindex $string 4]
        set zmin [lindex $string 2]
        set zmax [lindex $string 5]
        set width [hm_winfo graphicwidth]
        set height [hm_winfo graphicheight]
        set ratio [expr $width*1.0/$height]
        set height [expr $xmax-$xmin]
        set width [expr $height*$ratio]
        set emptySpace [expr ($width - ($ymax-$ymin))/4]
        *nodecleartempmark
        *view bottom
        *rotationangleset 90
        hm_viewccw
        *createnode 0 [expr $width] 0 0
        *createnode 0 [expr $ymin-$emptySpace/2] 0 0
        *window 0 0 0 0 0
        *nodecleartempmark
    proc ::miranda::rearView {} {
        *nodecleartempmark
        *view top
        hm_viewccw
        *createnode 0 [expr -1*$width] 0 0
        *createnode 0 [expr $ymax+$emptySpace/2] 0 0
        *window 0 0 0 0 0
        *nodecleartempmark
    proc ::miranda::takePhoto {filename} {
        *nodecleartempmark
        #Set graphics to color photos and white background
        *graphicsfilecolor 1
        *graphicsfileblankbackground 1
        #Take a photo
        catch {file delete -force $filename}
        hm_windowtofile [hm_winfo graphicx] [hm_winfo graphicy] [expr max([hm_winfo graphicwidth]/2-1,[hm_winfo graphicheight]-1)] [hm_winfo graphicheight] $filename
    proc ::miranda::toggle {object subObject status} {
        switch $subObject {
            bdf {set e 1; set s 0;}
            solid {set e 0; set s 1;}
            both {set e 1; set s 1;}
        foreach o $object {
            if { $status == on } {
                *createmark assem 1 $o
                *displaycollectorsallbymark 1 on $e $s
                *displaycollectorsallbymark 1 off [expr ! $e] [expr ! $s]
            } elseif { $status == off } {
                *displaycollectorsallbymark 1 off $e $s
        *unmaskall elements
#set up procedures
::miranda::main
#temporary file variables. Will be replaced by GUI.
set xsectUG "path_to_File"
set oldUG "path_to_File"
set newUG "path_to_File"
set oldBDF "path_to_File"
set newBDF "path_to_File"
# Old Geometry Plots
::miranda::toggle {oldModel newModel} both off
::miranda::toggle oldModel both on
::miranda::toggle oldModel bdf off
::miranda::takePhoto "$::miranda::path/old_model_solid_front.jpg"
::miranda::rearView
::miranda::takePhoto "$::miranda::path/old_model_solid_rear.jpg"
# New Geometry Plots
::miranda::toggle newModel both on
::miranda::toggle newModel bdf off
::miranda::takePhoto "$::miranda::path/new_model_solid_front.jpg"
::miranda::rearView
::miranda::takePhoto "$::miranda::path/new_model_solid_rear.jpg"
##cleanup
#::miranda::toggle newModel bdf on
#::miranda::plotNormals 0
#::miranda::thicknessVisibility 0
#::miranda::elementColor components
#::miranda::isoView front
