ydigit 34 Report post Posted November 7 AcuSolve results can be visualized in HyperView or AcuFieldView. HyperView is the easier option for most users (especially if you have used HV for some other solver). HV is a generic post-processor, so only basic CFD post processing is possible. However it covers the needs of many users. AcuFieldVIew is the expert tool for CFD, with advanced features for CFD post-processing. As with expert tools, it takes time to get used to it. So if you are new CFD user HV might be a good first choice. HyperView: HV can read results in following formats: 1.AcuSolve .Log file with ACUSIM.DIR in the same run folder. 2. Convert AcuSolve results to H3D a. AcuConsole > Tools > AcuOut. 2b. AcuOut is using the command acuTrans to convert the files. This command can be executed directly from the AcuSolve Cmd Prompt . AcuFieldView: Similar to above process for HyperIvew, you can export files to ..FV format as well. Quote Share this post Link to post Share on other sites
