lambefr
Large deformation in rubber sample
I am trying to model a rubber material that has 300%+ elongation capacity.  I don't need to model the rupture mode, just the fact that it can deform elastically and return to its original shape.  I tried with LAW2 and LAW42 but my solid elements (BRICK) just seem to explode when I reach close to 100% elongation.  I tried different ISOLID (1,14,24), but I always get the same result.
Any advices welcome, thanks.  Images of model and .rad, .out below.
Law2_finer.zip
Using LAW42 would be recommended since it is a rubber material.
Using Ismstr = 10 is recommended with hyperelastic material laws.  As HyperMan shows, /PROP/SOLID, Isolid=14 with Ismstr = 10 works.
Or you can use /PROP/SOLID, IHKT = 2 with Isolid = 24 (HEPH) and Ismstr = 10 which runs a little faster and also works.
We have this statement in the comments of /PROP/SOLID but I realize it is easy to miss.
Quote
For foam or rubber materials such as laws 38, 42, 69, 82 and 88, it is recommended to use IHKT = 2 with Isolid = 24 (HEPH) and Ismstr = 10, 12 (Lagrange type total strain).
Thanks,
Andy
