Sign in to follow this
hardydragon
CSV Export Data, dq From ABC Macro
Hello All,
Question 1:
This is regarding a script in the Flux 2019
..\Altair\2019\flux\Extensions\Macros\CreateLookUpTableFromTMProject.PFM
In this script there is part for exporting data
# export table in CSV format
   CSVExportTable(parameter=[VariationParameter['FLUX_A'],
                             VariationParameter['FLUX_B'],
                             VariationParameter['FLUX_C'],
                             VariationParameter['TORQUE']],
               evolutivePath=EvolutivePath(parameterSet=[SetParameterXVariable(paramEvol=VariationParameter['ID_PILOT'],
        limitMin=-IdMax,
        limitMax=IdMax),
                                                         SetParameterXVariable(paramEvol=VariationParameter['IQ_PILOT'],
        limitMin=-IdMax,
        limitMax=IdMax),
                                                         SetParameterXVariable(paramEvol=VariationParameter['ANGPOS_ROTOR'],
        limitMin=0.0,
        limitMax=LUT_angle_period_deg)]),
               filename=nameProject+'_MS_CSV_table')
Context:
I stopped the solving process the "CreateLookUpTableFromTMProject.PFM" executed this "CSVExportTable" function.
Problem.
I started the the solving process again and now I want to execute this function outside in the PyFlux Command.
I want to export all the solved data into CSV format.
How I can do this?
Question 2:
CreatePark_Iabc_Drivenby_Idq.py
In this script this is mentioned
   print "\n ***  user guide  ***\n"
   print " Your project is ready to be solved with RUN_ID_IQ solving scenario."
   print " You should define sensor for computing phi_a, phi_b and phi_c."
   print " You may use the macro CreatePark_dq_From_abc in order to compute directly phi_d and phi_q."
   print "\n*** Successfull end of CreatePark_Iabc_Drivenby_Idq macro ***\n'"
"CreatePark_dq_From_abc"
However, I know where find this macro.
Where I can find this macro?
Best Regards,
HK
Here the answer to your questons :
Question N°1 :
To export the data in CSV formt you can use the same python command as in the script or you can get the commande by exporting a curve in SCV formt from Flux 2D. If you want to do this for all the datan you can create a loop which allows you browse all the curves. The second choice is export the curve in CSV format one by one using the command generated before.
Question N°2 :
You will find attached the macro.
Hope this will help.
Best regards.
CreatePark_dq_From_abc.PFM.zip
