AAU 0 Report post Posted November 11 Hi, I am trying to run the indoor_propagation.cpp example on Visual Studio. I have used cmake for creating the VS project but when I try to just run the example, I get the following error: Is there any step I am skipping? Thanks in advance. Quote Share this post Link to post Share on other sites
reinerh 11 Report post Posted November 12 Hi, often the files on the C drive are protected, so you should either install the WinProp API package on the D drive or run Visual Studio as administrator. Quote Share this post Link to post Share on other sites
AAU 0 Report post Posted November 12 Yes, I was aware of that and I tried as administrator. However the problem persists. Quote Share this post Link to post Share on other sites
AAU 0 Report post Posted November 12 I got the solution. The problem was it must be specified "set up as startup project" in the actual project. By default is placed on "ALL_BUILD" which is incorrect. Quote Share this post Link to post Share on other sites
AAU 0 Report post Posted November 12 Now this is the problem that I have: Quote Share this post Link to post Share on other sites
AAU 0 Report post Posted November 14 Problem solved. In case someone is interested: When I installed the Feko + Winprop software I pointed the environment variable to the license server. However, when using the API you need to configure it as a Windows enviroment variable to make it work. Quote Share this post Link to post Share on other sites
