ezzymn
HyperMesh 2019 Assembly View
Hi all,
After upgrading from 2017 to 2019, I've noticed that in the standard model browser window under "Model View", you can see any assemblies but they do not expand in that pane. Instead you need to double click or go to "Assemblies view".
The only issue with this, is that the "Assemblies View" only contains components and not groups etc.
Is there a setting to behave like 2017 and allow the assemblies in "Model View" to expand?
Many Thanks
2019 - "Model View" Unexpandable
2017 "Model View" - Expandable
2019 "Assemblies View" - No Groups or Properties etc
That's the configuration browser isn't it?
So that allows me to see / hide assemblies within the model view, but not the ability to expand assemblies within the model view
Hey Tinh,
Tried that, and it doesn't do as we want I'm afraid.
Another little thing I've just noticed. Everytime you go to the "Assembly Viewer", it switches the mesh view to "By Assem", which is rather annoying...
Hi
When you enter the dialog "browser cinfiguration", did you see any check box named "Assembly Hierarchy"?
Or you just see "Assembly"?
Sorry to ask too detail because I don't have hm2019.
Hi Rahul,
Thank you for the video, I learnt things that I wasn't expecting.
But the problem still stands - I can't open the part browser in the other side, as we have our utility menu there.
The Assemblies don't expand in the Model Browser
The Part Assemblies don't expand in the Model Browser.
The solution of opening another view on the right task bar just won't work for what we do.
@tinh - Enitities - Assemblies
Hi @ezzymn,
You can disable auto color by entity type in the Browser Configuration dialog.  Uncheck "Autocolor visualization mode" under Local Options.
It is worth noting that Assembly View of Model browser shows only Assemblies and Components, so it is not possible to interact with entities such as Groups, Properties and Materials.  In Part browser, dedicated columns show you the Component, Property and Material associated with the Part.  See the image below:
Since Parts may not be relevant to your workflow, feel free to contact me via DM so I can learn more about your use case and offer additional assistance.
Cheers,
Joe
Rahul R likes this
I thought so.
Could you please open command window (menu Views>command window) and then enter below command:
set ::env(HMBR_CONTENT_HIDE_ASSEMBLYHIERARCHY_FOLDER)
and then take a screenshot?
I want to see the settings on hm2019
Hi @ezzymn
I seem to find out where the settings can be customized.
It's exactly stored in below files:
<install dir>/hm/scripts/br/views/model/regular/
Please copy the folder 'regular' and zip it then post it here. I will modify settings and send back to you.
Don't modify it by yourself because it's easy to be fault.
Hi @tinh
can't read "::env(HMBR_CONTENT_HIDE_ASSEMBLYHIERARCHY_FOLDER)": no such variable
I feel like the functionality might be removed, but I appreciate you having a look. I've tried the crude attempt to copy over the 2017 files, but that segmentation faulted.
Reports.7z
Many Thanks
Eric
@ezzymn
As you have correctly deduced, there is no option to show the Assembly hierarchy in 2019.  Depending on the version of 2019 you are using, I can provide a patch that brings back legacy behavior - let me know if you are interested.  As mentioned in my previous post, I am still keen to meet to discuss our the paradigms and workflows we have in 2019.
As a FYI, legacy behavior will return in 2020.  Additionally, Part hierarchy has never been shown in Model View, though this may change in the future.
17 hours ago, ezzymn said:
Hi @tinh
Many Thanks
Eric
Hello
I modify some things
Please copy these modified files and overwrite the old ones
If something's wrong, simply backup original files and let me know issuesReports_modified.zip
@tinh, Thank you I'll try and find some time today to try it.
@joek, Sorry I haven't been ignoring you. I'll give this try from tinh a go, and if that doesn't work then a patch would be much appreciated
Hi @tinh, in "Assemblies view" I can create Assembly/Component within each Assembly:
But with "Model view" (your modified version) I can not do that (maybe the same issue in initial version):
Do you think it's possible to customize this context menu by adding "Create ..." ?
Thanks,
@joekI know you guys don't like to discuss product road maps on a forum like this, but will be there be another major dot release of 2019 HW suite (like 2019.2) before arrival of 2020 release (if we go by 2019 release time frame, it could happen almost 5-6 months in to next year)? There are lot of bugs and features missing, especially in HWX. I realize not all can be added or rectified but I am hoping for another major dot release to make HWX little more usable until 2020 release.
Thanks...
I deem persons before become HM developers should be HM users, so they could upgrade software better. Anyway it's a really good software because we can do almost things by Tcl ;)
17 minutes ago, tinh said:
I deem persons before become HM developers should be HM users, ....;)
Yes, it's the ideal case. But in reality, that is not always true.
The "Model view" of 2019.0 & 2019.1 (with useless Assembly tree)  is a typical example of developers who don't take care of what users want.
On 11/23/2019 at 7:53 AM, tinh said:
Yes, I do.
I will try hooking the menu. Just need a little time to find where it is.
Hi Mr. @Q.Nguyen-Dai
I seem to find it in hm2017
I don't have hm2019, could you please zip folder <install_dir>/hm/scripts/br  and post here.
Q.Nguyen-Dai likes this
