oguzhan
Composite: Linear static analysis - Tutorials & Tipps?
Hello everybody,
I am inexperienced with this software and generally with the simulation and analysis. I would be very happy to have your help.
I would like to perform a linear static analysis (stiffness). The model is a carbon fiber upper arm and i have the following questions:
Question 1: When I start HyperMesh Desktop 2019 an application called "User Profile" opens and i have to choose one of them. Do you know which is the correct one to start in my case. (OptiStruct?)
Question 2: I have access to connect.altair and altairuniversity. There are some tutorials which explain that you have to import the model into hypermesh but i cant find them.
Do you know where they are?
Could you give me some tipps for my Project?
In this regard, I want to perform the following steps:
1. Import 3D geometry from CATIA to HyperMesh (OptiStruct)
2. Define the geometry
3.Preprocessing of the composite
• Modeling of the composite material
• Create Laminate Modeling Concept
• Design of composites with HyperLaminate
• Define load and constraints
4. Perform analysis
5. Post-processing of the results
Best regards,
Coban
choose the Optistruct user profile.
Here is a video on how to import geometry:
I recommend you go through FREE eBooks:
Practical Aspects of Finite Element Analysis
Introduction to Practical Aspects of Composites with Altair OptiStruct
Check the following webinar:
Alo search for other videos related to composites:
https://www.google.com/search?q=composite+optistruct&sxsrf=ACYBGNSfNx5x1oRFY-AfexZKWyQXsUDT-w:1574068736682&source=lnms&tbm=vid&sa=X&ved=0ahUKEwj3n5v_tvPlAhWvlosKHTfYBU8Q_AUIEygC&biw=1858&bih=977
Thank you very much for your answers! But I am still struggling to import the CATIA Model to HyperMesh (Optistruct), although I am using the licensed version of CATIA V5. (Attached you will find a picture of the failure)
Optistruct offers three composite modeling methods e.g. PCOMP, PCOMPG and PCOMPP. So I decided to use the PCOMPP composite modelling method, because it is a ply based  method. Do you think it is the correct one?
Thanks in advance!
Best regards,
Oguzhan
