Saml
Error MESSAGE ID : 146
Dear all,
I run a simulation two days ago but after few hours the workstation restsrts. Now I want to restart the simulation but the solver gives the this error:
MESSAGE ID :        146
 ** ERROR : RESTART FILE NOT COMPATIBLE WITH THIS VERSION
     ERROR TERMINATION
Hoe can I sole the problem?
In attachment my out file.
Modello_12_wFail_0002.out
the file you shared is empty. Either the restart file is not compatible with the version you are using or there is some problem with the restart file. Can you share the model?
This error was already posted:
It is possible the restart file is corrupt- try deleting (or just moving to another folder) the last restart file and restarting from the second to last. Restart file without a model file is useless. Unfortunately, I can not provide further help with the given information. Check FAQ on restart:
Restart.pdf
