FBa
Degrees of freedom for independent RBE3 nodes
Hi community,
is there a way within HyperMesh to define the degrees of freedom for the independent nodes of an RBE3 element? They're automatically set to DOF123.
I work with Nastran and can manually edit the bdf file after export but this is most often very impracticable.
Thanks!
Florian
Hello FBa,
You can edit the element RBE3->Update->dofs and switch "select to type" into "set individual".
Now you can set the dofs and update the independent node. See picture.
Best Regards,
Mario
