hypermeshed
No .h3d-file created
I was doing a modal analysis with HyperMesh. I have done the same steps as in this instruction. When I finally do OptiStruct, the solver runs without error message. At the end it says "Jobs completed". But when I want to see the results in HyperView, I get the message, that there is no .h3d-file found. I looked up in the folder and there was no .h3d-file created. I do not know why because there is no error shown.
It works this way: If I do not create a second load collector and set the card image of constraints to EIGRL, then a .h3d-file is created. So the problem might be something with the constraints and the EIGRL load collector. But the steps I did are the same as in the instruction above.
Can someone help me?
Greetings
