Emanuel
AcuSolve Multiphase simulation
Hi there!
I am trying to simulate a flow of humid air running through an helical pipe. As the air flows, it gets cooled from a negative heat flux on the walls of the pipe.
Any thoughts on how can I approach this problem? Currently, I am not able to run the simulation because I get an error "Negative absolute pressure for humid air".
There are several issues with your setup.
Why do you have a mesh motion with ALE? I guess that was unintentional.
Also any reason for the pressure offset?
Try running with these two adjustments (no mesh motion and no pressure offset) and report if it works...
I changed the pressure offset and then switched the fluid to laminar instead of turbulent. Now it seems that it works.
My reasons to use a moving mesh is because I would like to simulate the centrifugal force that comes from the fluid passing through the helical tube.
I am adding the .inp file and the .log, let me know if my approach is wrong.. thanks!
test_hm.inp test_hm_sim.14.Log
Why are you using the pressure offset in the first case? I would remove it, unless you know why you introducing it. Also the current value of 10135 seems really odd (assuming you meant it 101325 = 1bar?).
Keep turbulence (default SA model) on, as that generally helps with convergence.
Mesh motion is needed when there is some explicit movement of a part (say FSI or rotating fan or flexible body). In your case I do not see a reason to enable mesh motion.
