Sign in to follow this
Beginner93
Hardening parameters in law36 is not positive
can anyone tell me if it´s possible to use a non monotonously rising curve for the material definition in a nonlinear static and implicit analysis with Radioss? The modell is built with solid elements (brick8) and m36 material definition.
I know with Optistruct it is not possible to use a falling curve.
A picture of the curve is in the attachement.
Thanks a lot and greetings,
Luca
the stress-strain slope should be positive (the data points must be in ascending order). Convert the engineering stress-strain to true stress-strain. The first point of yield stress functions (plastic strain vs stress) should have a plastic strain value of zero. The curve should be nearly flat (slightly increasing) after the ultimate strength. To model failure use εt,εm, and εf parameters or dedicated failure models.
Materials.pdf
