brenton_101
Turbulence Intensity Unit Clarification
I have a question regarding the Turbulence Intensity parameter that is located under the solver browser in Hypermesh 2019.1 (AcuSolve User Profile).
What are the units of this parameter? Is it represented as a percentage or ratio? (I've attached a screen snippet)
For example in AcuConsole GUI, the turbulence intensity parameter is input as a percentage (e.g 2.5 for 2.5% turbulence intensity).
Best regards
Brenton
Hi Ydigit,
The issue is not with the definition of turbulence intensity but that my turbulence intensity parameter may be out by a factor of 100.
In AcuConsole, the parameter is called Percent Turbulence Intensity, so for this I would simply input a value of 5 corresponding to 5 percent.
However in HM Solve Browser, the parameter is called Turbulence Intensity. So should I input a value of 5 or 0.05 to represent 5 percent??
Hope this clears up any confusion.
oops, I understood the question incorrectly.
The default when creating a new inflow is 0.03.
So it is good to assume that 0.05 would be a good input in your case. Also if you would like to verify this, you can open the .INP file that HM will generate after export in a text editor.
Hope this helps.
