Roshan Shiveshwar
Issue with node set export- SimLab 2018
I am currently using SimLab 2018 for pre-processing.
When I export the FE model as Ansys .cdb file from SimLab and import it in Ansys solver,  the sets are not getting imported.
The sets are expected to be imported as "COMPONENT SETS"  which used to happen when I was using older SimLab versions.
Is there something that I am missing out during Solver Input File export or some bug in the appplication?
SimLab version details:
Hi Roshan,
Following sets are supported in SimLab for Ansys interface.
  1. Node set
  2. Shell element set
  3. Solid element set
If you create the above sets, it will write "CMBLOCK" card in ANSYS solver deck file (*.cdb). I checked in SimLab 2018 version and it works fine.
Can you please let me know which set you created?
Thanks & Regards,
Santhoshkumar
Senior Application Specialist
Altair | Nasdaq: ALTR
santhoshkumar.sundararajan@altair.com | altair.com
Connect with us: LinkedIn | Twitter | Facebook
This message is a private communication intended only for the use of the addressee and may contain information that is PROPRIETARY and CONFIDENTIAL. If you are not the intended recipient, you are hereby notified that any dissemination of this communication is strictly prohibited. If you have received this communication in error, please erase all copies of the message and its attachments and notify the sender by replying to this message. Thank you.
Thanks Santosh for the response!
I re-evaluated the .cdb file again and  following are my observations:
  • Export cdb from Simlab 14 :  The .cdb file gets imported in Ansys(MAPDL) without any issue. Node sets are also accessible.
  • Export cdb from Simlab 2018 :  While importing .cdb file in Ansys(MAPDL), I get warning messages. If I allow these messages, the import gets completed and node sets are accesible or else the model data will be partially imported (which was happening previously)
Below is the screengrab showing the warning messages.  So, far  these warnings have not harmed us.  Yet,  we are trying to figure out what these messages imply.
message-Ansys.thumb.png.1d621434d6f9533972240ceff9b1740b.png.
Hi Roshan,
I created node sets in SimLab 2018 version and exported as ANSYS cdb file. Import the ANSYS cdb file in ANSYS (MAPDL) and I did not see any error.
Attached the sample ANSYS cdb file exported from SimLab 2018 version. Can you please import this cdb file ANSYS (MAPDL) and see whether you are getting any error?
Also, can you please send a sample cdb file exported from SimLab 2018 version? We will check this and get back you.
Solid_Cube.cdb
