Umichchelsea
Proman does not output anything
I am new to WinProp and try to learn how it could be used through the examples (like Indoor_Sample_IRT in the directory where WinProp is installed). However, when I import the project into Proman and run propagation analysis, no output file or results has been generated. There is no warning or error message being generated. Do you have any idea on how this happens?
Thank you.
The first thing to try is to copy the examples to a location where you are certain that there will be no problems with write permissions. (Maybe you had already done that).
