alpha
Mesh convergence Study with Simlab
Now I am using Simlab 2019.2 and found that there is no need to record the process to do Mesh Convergence Study?
I am not sure about this when I do not see the input for *.xml. Simlab keeps changing each versions.
In my opinion this will be difficult for company to create process.
I also face with the warning message when do the same as before?
I also tried to study mesh size convergence for my normal mode analysis. I want to know best mesh size for first and second mode (my model is 500K - 1M nodes).
However, mesh size study only support for *.h3d result. If use *.h3d result I cannot create response for frequency.
Could you advise for this?
SimLab is developing quite quickly, indeed many things are changing from version to version.
You can still create a makro and a DOE to implement your own mesh refinement DOE like in the past.
Additionally, you can try the new approach we are implementing currently.
You need to define a BODY MESH CONTROL on the geometry you want to "refine".  We still don't have complete tutorials for this, we plan to  add one to the Learning Center .
I am very interested on the convergence study option. Could you please share the information, as you comented on the previous message? Regards
