narasimhamurthy
Creating Markers and a Deformable Surface
i am trying to do rigid and flexible body contact. but getting error message, while creating Deformable surface through Macro - create Deformable surface from FEM as shown in picture.
can't read "Num_Occ()": no such element in array
    while executing
"if { $Num_Occ($NextRowPointer) == 1 } {
                            set MarkerNodeList([expr $NumMarkerRows + 1]) $NextRowPointer
    (procedure "::model::_private::Surface_Macro::CreateMarkers" line 264)
    invoked from within
    ("eval" body line 1)
    invoked from within
"# Compiled -- no source code available
error "called a copy of a compiled script""
    (procedure "::hwt::ReleaseCanvasButton" line 1)
    invoked from within
"::hwt::ReleaseCanvasButton 0 .modelPanel.surfCreate.bottom.btnGenerate"
    (command bound to event)
Please give suggestions to eliminate this error.
Thanks,
Narasimhamurthy
Hello Narasimhamurthy - Could you please share the version of MotionView you are using and also share the fem file if possible ?
regards
Praful
There are two tutorials in our Help that deal with deformable surfaces:
MV-1028: Modeling Point-to-Deformable-Surface (PTdSF) Higher-Pair Constraint
MV-1029: Modeling Point-to-Deformable-Surface Force (PTdSforce)
If you search our help just for "MV-1028" that should take you to the correct location.
Chris Coker
I have the same problem.
I was not able to import the FEM membrane when I created it in HyperMesh. (same error)
I was only able to update the FEM membrane from the training model and used this. It's worked for a small model, but the biggest project coming. And I will need to solve this as soon as possible.
I have reviewed the help and I have found this information only:
Quote
Important: This macro requires that the FEM model file have a constant number of nodes in each row
But I don't understand the meaning of this limitation. Because I have created a rectangle shape as you can see below. And I was not able to import it via this macro.
I suppose that there are other limitations for the FEM model to use it for this macro.
Please let us know if you have any information which can help us.
Thank you.
Pavol
