Sign in to follow this
mzafar
Importing customized results into HV via csv file
I am trying to import a csv-file containing Element-ID's with the corresponding custom results.
I have done a little research and got to know the generic ASCII reader for which I have to create the csv file with a specific header.
My csv file looks like this:
ALTAIR ASCII FILE
$DELIMITER = ,
$TITLE =  STATIC ANALYSIS
$SUBCASE_ID = 1 Unit_force
$BINDING = ELEMENT
$COLUMN_INFO = ENTITY_ID
$RESULT_TYPE = My_Result(s)
1, 26
2, 12
3, 10
4, 11
5, 25
6, 9
7, 28
8, 27
9 7
10, 8
11, 31
12, 15
13, 32
14, 14
15, 21
16, 13
17, 33
18, 34
19, 29
20, 3
21, 2
22, 36
When creating the csv-file, I change the file name ending from ".csv" to ".hwascii".
In HV I try to load the model via a fem-file and the results file via the created hwascii-file (see above).
Unfortunately, this doesnt work as I always get the following errors:
"INFO" "20:15:13" "Error: missing reader or invalid 'path' attribute for resource (model): "C:\Users\Mortasa\Documents\Test_LS_Model\LS_Model_15_15_solverdeck_mit_zusatz.fem""
"INFO" "20:15:13" "Error: exception occured (Model Adapter: AddInstruction failed)."
"INFO" "20:15:13" "Error: invalid resource (model) attribute for 'add' instruction (model)."
"INFO" "20:15:13" "Error: failed to load resource 'model' using reader 'ResultModule XML Reader'."
"INFO" "20:15:13" "Error: can't compile analysis object (resource : model)."
"INFO" "20:15:13" "Error: can't compile analysis object (resource : Resource_1)."
"INFO" "20:15:13" "Error: missing reader or invalid 'path' attribute for resource (Resource_1): "C:\Users\Mortasa\Documents\Test_LS_Model\a.hwascii""
"INFO" "20:15:13" "Error creating result math analysis [General]"
My fem-file looks like this:
$$ Optistruct Input Deck Generated by HyperMesh Version  : 2017.2.0.16
$$ Generated using HyperMesh-Optistruct Template Version : edu2017.2
$$   Template:  optistruct
$$ optistruct
ELFORCE = ALL
$$                      Case Control Cards                                      $
$HMNAME LOADSTEP               1"Unit_force"       1
SUBCASE       1
  LABEL Unit_force
ANALYSIS STATICS
  SPC =        2
  LOAD =        1
$$ HYPERMESH TAGS
$$BEGIN TAGS
$$END TAGS
BEGIN BULK
$$  Stacking Information for Ply-Based Composite Definition
PARAM,K6ROT,100.
PARAM,POST,-1
$$  GRID Data
GRID           1        -25.0   0.0     -50.0
GRID           2        -25.0   0.0     -45.0
GRID           3        -25.0   0.0     -40.0
GRID           4        -25.0   0.0     -35.0
GRID           5        -25.0   0.0     -30.0
GRID           6        -25.0   0.0     -25.0
GRID           7        -20.0   0.0     -25.0
GRID           8        -15.0   0.0     -25.0
GRID           9        -10.0   0.0     -25.0
$HMNAME BEAMSECTCOLS           1"BEAMSECTCOL_1"
$HMNAME BEAMSECTS
$              1       1"CBAR_Prop"
$              1       0      24       0     1.0     1.0     0.0     0.0     0.0
$            0.0       1
$HMNAME BEAMSECTS  RESULTS_AREA 19.63
$HMNAME BEAMSECTS  RESULTS_CENTROID     0.0     0.0
$HMNAME BEAMSECTS  RESULTS_IUSER        0.0     0.0     0.0
$HMNAME BEAMSECTS  RESULTS_ICENTROID    0.0     0.0     0.0
$HMNAME BEAMSECTS  RESULTS_IPRINCIPAL   0.0     0.0
$HMNAME BEAMSECTS  RESULTS_THETA        0.0
$HMNAME BEAMSECTS  RESULTS_S    0.0     0.0
$HMNAME BEAMSECTS  RESULTS_Z    0.0     0.0
$HMNAME BEAMSECTS  RESULTS_SP   0.0     0.0
$HMNAME BEAMSECTS  RESULTS_ZP   0.0     0.0
$HMNAME BEAMSECTS  RESULTS_RADIUSG      0.0
$HMNAME BEAMSECTS  RESULTS_COORDEXT     0.0     0.0
$HMNAME BEAMSECTS  RESULTS_COORDEXTP    0.0     0.0
$HMNAME BEAMSECTS  RESULTS_SHEARCENTER  0.0     0.0
$HMNAME BEAMSECTS  RESULTS_SHEARCENTERP 0.0     0.0
$HMNAME BEAMSECTS  RESULTS_ELASTICCENTER0.0     0.0
$HMNAME BEAMSECTS  RESULTS_SHEARDEFORM  0.0     0.0     0.0
$HMNAME BEAMSECTS  RESULTS_PRINCIPALSHEAR       0.0     0.0
$HMNAME BEAMSECTS  RESULTS_SHEARANGLE   0.0
$HMNAME BEAMSECTS  RESULTS_SHEARSTIFF   0.0     0.0     0.0
$HMNAME BEAMSECTS  RESULTS_J    0.0
$HMNAME BEAMSECTS  RESULTS_GAMMA0.0
$HMNAME BEAMSECTS  RESULTS_EMT  0.0
$HMNAME BEAMSECTS  RESULTS_PMT  0.0
$HMNAME BEAMSECTS  RESULTS_TORSIONCOEFF 0.0     0.0
$HMNAME BEAMSECTS  RESULTS_NUMBEROFCELLS       0
$HMNAME BEAMSECTS  RESULTS_GLOBALCENTROID       0.0     0.0     0.0
$HMNAME BEAMSECTS  END
$$ RBE2 Elements - Multiple dependent nodes
RBE2         601     683  123456      37      38      39      90      91
+             92      93      94      95      96     181     182     184
+            185     187     188     189     190     193     194     195
+            223     224     225     226     311     312     314     315
+            317     318     319     320
$HMMOVE        5
$            601
$$  CBAR Elements
CBAR         602       2      62       61.0     2.368-140.0          BGG
$HMMOVE        4
$            602
$$  CQUAD4 Elements
CQUAD4         1       1      22      25      26      21
CQUAD4         2       1      21      26      12      13
CQUAD4         3       1      25       9      10      26
CQUAD4         4       1      26      10      11      12
CQUAD4         5       1      23      27      25      22
CQUAD4         6       1      27       8       9      25
CQUAD4         7       1       4       5      28      24
CQUAD4         8       1      24      28      27      23
CQUAD4         9       1       5       6       7      28
CQUAD4        10       1      28       7       8      27
CQUAD4        11       1      18      29      31      17
CQUAD4        12       1      17      31      15      16
CQUAD4        13       1      29      30      32      31
$HMMOVE        2
$              1THRU         600
$$    HyperMesh name and color information for generic components               $
$HMNAME COMP                   1"2D_Surface"
$HWCOLOR COMP                  1       4
$HMNAME COMP                   2"2D_Mesh"        1 "LS_Prop" 4
$HWCOLOR COMP                  2       5
$HMNAME COMP                   4"CBAR"        2 "CBAR_Prop" 3
$HWCOLOR COMP                  4      17
$HMNAME COMP                   5"RBE2"
$HWCOLOR COMP                  5      25
$$  PSHELL Data
$HMNAME PROP                   1"LS_Prop" 4
$HWCOLOR PROP                  1      21
PSHELL         1       11.5            1               1        0.0
$$  PBAR Data
$HMNAME PROP                   2"CBAR_Prop" 3
$HWCOLOR PROP                  2      24
$HMBEAMSEC PBARASSOC           2       1
PBAR           2       119.63   0.0     0.0     0.0     0.0
$$  MAT1 Data
$HMNAME MAT                    1"Steel" "MAT1"
$HWCOLOR MAT                   1      20
MAT1           1210000.0        0.3     7.82-9
$$ HyperMesh Commands for loadcollectors name and color information $
$HMNAME LOADCOL                1"Force"
$HWCOLOR LOADCOL               1       6
$HMNAME LOADCOL                2"Constraints"
$HWCOLOR LOADCOL               2       7
$$  SPC Data
SPC            2     378  123456     0.0
SPC            2     379  123456     0.0
SPC            2     380  123456     0.0
SPC            2     381  123456     0.0
SPC            2     382  123456     0.0
SPC            2     383  123456     0.0
SPC            2     384  123456     0.0
SPC            2     385  123456     0.0
SPC            2     430  123456     0.0
SPC            2     431  123456     0.0
SPC            2     444  123456     0.0
SPC            2     445  123456     0.0
SPC            2     446  123456     0.0
SPC            2     447  123456     0.0
SPC            2     448  123456     0.0
SPC            2     449  123456     0.0
SPC            2     450  123456     0.0
SPC            2     451  123456     0.0
SPC            2     528  123456     0.0
SPC            2     529  123456     0.0
$$  FORCE Data
FORCE          1     683       01.0     1.0     0.0     0.0
ENDDATA
$$        Data Definition for AutoDV                                            $$
$$        Design Variables Card for Control Perturbations                      $$
$$        Domain Element Definitions                                            $
$$            Control Perturbation                                              $$
ALTDOCTAG "Q\5jUX^O3QoPMS0;2p2MI0DfFjM:gmml1Zb3@hkE:IBC:KF7cY;cEGYerq0fRQIBfEgMPcBYemflZIQAI@fQYNn78?90o[p6IQmg@UrL9T`];^R9NL\53XXX"
ADI0.1.0 2019-08-26T20:18:55 1of1 HM11.0
ENDDOCTAG
It has to be said that I am not able selecting any reader options via the button in the loading panel of HV, so I am not really sure, if the generic ASCII reader automatically comes into action when the user tries to load a hwascii-file via the load results panel or if the generic ASCII reader isnt available for usage with the student edition.
I am using the HyperWorks student edition 2017.2.
Hopefully you guys can help me out.
Kind regards.
