Shi Feng
Automatic report generation by tcl/tk and API in hyperview
hi, guys!
In hyperview, I want to generate the report by tcl commands. But in the class hierarchy, I couldn't find the way of defining the handle about ppt (hwIPPTPublish_handle). It is appreciate for you to help me solve this problem.
Thank you  very much.
Its in the session class. Attached is a sample script that shows using PPTPublish handle
hwi GetSessionHandle sessionH
sessionH GetPublishingHandle pub
set pfadPPT "D:/tmp/test.ppt"
catch { sessionH ReleaseHandle }
catch { pub ReleaseHandle }
catch { ppt ReleaseHandle }
hwi OpenStack
pub GetPPTPublishHandle ppt
ppt SetDestination new
ppt SetPathOnDisk $pfadPPT
ppt Publish
ppt SaveLinkedPPTPresentation $pfadPPT
ppt CloseLinkedPPT
hwi CloseStack
Hi, Livil Lyle.
Thanks for your answer. I also thinks that it is in the session class. But I could not find this command--GetPPTPublishHandle. When I try to use this command, the system shows the message that "Object named: sessionH (of type hwISession) could not find requested method: GetPublishingHandle. Or the method was called with incorrect arguments." The version that I use is 14.0. I have no idea how to solve this problem. It is appreciate for you to help me in this aspect.
