RAVITEJA_028
coil construction using litz wires
I am working on induction heating cookers. I need to model the coil using litz. so is there a example or documentation that i can use to make the coil. I am attaching the coil type that i have to model.
thank you
Unfortunately we don’t have any example about coil using Litz wire. But if you want to take into account of the proximity effect you can use coil conductor region with loss. This region is available only in steady state AC magnetic.
Best regards
