alpha
How to fix rotating center?
When I operate the model, it always change the Rotating Center when I rotate model by Middle mouse on the model.
May I know how to fix rotating center of model?
You can not fix the rotating center using the mouse. Every time you middle click to rotate, this will select a new rotating center.
What you can do if this disturbs you is:
- use a 3D space mouse: in this case, the "2D"mouse middle click will  fix the rotation center, the 3D mouse will do the rotation
or
- choose under File|Preference|System a different Mouse setting. FOr example, "Hyperworks 13.0" allows to choose the rotation center and rotate separately, like in Altair HyperMesh.
