Sign in to follow this
JKL
Issue with results
Hi!
I am performing an axial quasi-static crash test of a crash box. However, the results are not at all plausible. I have checked all the parameters of the material as well as the properties.
Please help! Which parameters should I change in my model?
Thank You!
TP005_1_0000.rad
The engine file is not included (again). Use Engine File Assistant to easily define control cards. Engine file can be merged with starter on export: check the "Merge starter and engine file" option so the engine control cards defined will be in the starter file (_0000.rad). Open the _0000.rad file in Textpad or Notepad and ensure that engine control cards are present.
It is not obvious how the model is not plausible- do you have experimental tests or previous experience? I can only think of the axial crushing might be too stiff. A geometric imperfection can be introduced with a /RANDOM nodal noise.
There are intersections and penetrations in the contact interface which should be corrected. There are also 10 bad quality elements (negative volume).
