Endeavor
Mid surface meshing
I have created the mid surface of sheetmetal plate and have already meshed the mid surface with quad elements. In the geometry tab, I was able to give thickness to mid surface geometry. How can I apply the thickness to the elements in the mid surface mesh?
Thanks and regards!
I meant this Geom as geometry tab. Thanks for your input.
Now, I have created the property with respective thickness and assigned it to the component. Could you please tell me, if there is any way I can check whether the thickness has been assigned to the mesh elements? I do not see the 3D representation option in Hypermesh!
There are probably many methods to check the thickness assigned to elements. Display By Thickness:
You can also use the visualization toolbar (View>toolbars>Visualization) for the 3D representation.
