Sign in to follow this
hypermeshed
Error 902 CWELD
I try to connect two meshes with connectors to simulate a weld. I have spot connectors with type rod. Then I defined a new property with PWELD and steel as material and assigned it to the connectors component. It is to connect two steel beams.
When I now want to run OptiStruct, I get Error 902:
 *** ERROR # 902 ***
 Weld uses an ALIGN connection type and
 GA (or GB)
 is not a vertex grid of a shell element.
 CWELD element id = 313472.
 GRID id = 63648.
Can someone help me?
