Julian_R
3-point-bending of composite sandwich structure
Hello guys,
we conducted a 3-point-bending test of a composite sandwich panel in university. We used a 10mm Rohacell foam core and 2 sheets of CFRP (3 layers each).
I tried to model it in Hypermesh to compare the results. In the real test, we got a deflection of 6,4 mm by an applied force of 2000N.
In my Hypermesh model we got a deflection of 332mm which seems unlikely. Can someone take a closer look at the file and tell me what is wrong?
Thank you!
1.hm
Hi Julian,
I have just checked your model.
It looks like the Rohacell core material is extremely light.
You have given young's modulus of just 70 Pa to it which is very less.
I gave the E value as 7000 and G value as 1900 and ran the analysis.
And, i got the following result which is satisfactory.
Hello Koushik,
thank you for your quick answer. So the material properties like E and G in an isotropic Mat1 card are expressed in Pascal and not Megapascal like you shown me.
But how is it in an Mat8 card for an orthotropic material? I put the values in the file I attached to my previous post for my carbon fibre laminate in Megapascals as you can see.
Is it right or do I need to change the values too, like for the Rohacell foam core in the Mat1 card?
Thank you!
