hypermeshed
Create a simple weld
I get caught on a simple welding. I have two components meshed with 3D elements. Now I just want to create a simple weld to connect both meshes, no more.
I used 3D -> Connectors -> Seam
Then I selected some nodes where the weld should be. I activated "reatin nodes", connect to components with elements, tolerance to 5 and as type weld.
But it does not connect the two meshes this way.
How does it work?
