Sign in to follow this
Crashphys
Modal Analysis with Rigids
I am trying to connect the beam modelled as 3D elements to the composite plate. Is there a faster way to do this? I tried using spot connectors and it did not work...
It turns out that the reason connectors are not working well is because I am running a modal analysis. Can anyone explain why rigids cause problems in modal analysis?
Edited by Crashphys
Scope of problem changed.
