Sign in to follow this
Ciro.Alosa
Mesh information is not consistent
Hi, I have a machine with an ODD periodicity. When I check the physics it says:
"The lines :
11
in the image plane have no origine counterpart.
The geometry is not periodic."
I don't know what to do.
Thanks
Can you check the type of mesh generator that you have used in this line?
If the line is in the periodicity plan, you need to use a linked mesh generator.
 If the problem persist, can you send me you Flux project (zip format).
Best regards.
