Sign in to follow this
Roshan Shiveshwar
Query Young's Modulus, Poisson's ratio in Ansys profile
Hi ,
I am trying to query  Young's Moduls, Poisson's ratio of a material Ansys profile.
The following command doesn't seem to work -
        set E [hm_getvalue materials id=$mat_id dataname=E];
        set Nu [hm_getvalue materials id=$mat_id dataname=Nu];
I also tried the following
Is there any way I can successfuly query all the attributes assigned to the material, irrespective of solver setings?
Thanks!
@tinh: on my 2019.1 Hypermesh, this command does not work. In the help I see:
hm_attributelistall
Returns a list of all attribute IDs, names, types or type names for the current template.
Syntax : hm_attributelistall value
Type : HyperMesh Tcl Query
Description : Returns a list of all attribute IDs, names, types or type names for the current template.
Inputs
value
    The type of list to return. Valid values are:
    id - the attribute ID
    name - the attribute name
    type - the attribute type number
    typename - the attribute type string
hm_attributelistall
Inputs
value
I think he meant
hm_attributelist mats 3 name
On 2/7/2020 at 7:23 PM, Q.Nguyen-Dai said:
Which "Card image" do you use for your material?  If you use "MATERIAL", you can try:
hm_getvalue mat id=1 dataname=MP_EX_VAL2
Thanks Q.Nguyen-Dai !
If the profile was Abaqus, I believe I have to use the following:
hm_getvalue mat id=1 dataname=Young
Now, since I want to write a code which is profile independent, I am wondering if there is a generic query command. (Atleast for basic properties such as Density, Young's modulus, Poisson's ratio etc.)
Yes, I am sorry for the mistake!
I mean hm_attributelist mats 3 name
@Roshan Shiveshwar if you want a generic way, you will have to filter tokens like E , young in attrib names
As i see, attrib names of profiles are not same. That means you should store them in a dict.
Yes. Even I felt the same. Create a custom library of required attrib names and use them as needed.
