uri
Mesh can't be created
The recommended element size is to have 3 elements by the width of the part.
The wall thickness  of the part is 4.5mm so I need an element size of 1.5 mm
When trying to do so I get a message of too many elements, 23.16 million elements.
(23.16 )*4.5(GB)= 104.22GB (Ram memory needed)
I have 128 GB Ram memory.
Should I enlarge my Ram memory to 256 GB?
Please advise.
Hey Uri,
Actually in installer we config .xml file, and there we need to increase the thrush hold value ,
C:\Program Files\Altair\2019.4.2456\InspireCast2019.4.2456Dev\hwx\plugins\freedom\profiles\c2c\config\solverConfig.xml, (you can  change the setting in this file)
<param txt="Max num of elements allowed for run" dv="20" id="max_allowed_num_elem_run"/>
change the 20 value to your requirements.
I have a question for you Uri: How did you calculate the RAM
Thanks
Hi Uri,
Thank for the answer, getting back to our previous conversation I would recommend you to increase the RAM , although running with 20 million elements is not that worth. Anyways is it possible for you to share the file? I can have a look at it.
Thanks
