darad
Simlab: Output applied load and reaction force summary
This turns out really easy in Simlab.   Simply create a text file for input/output with the following:
OLOAD
SPCFORCE
Near bottom the output *.out file, look for:
Subcase:       1
 Label     x-force    y-force    z-force   x-moment   y-moment   z-moment
Sum-App. -1.893E+04  8.693E+04 -7.083E-12 -8.721E+06 -1.899E+06  1.942E+07
Sum-SPCF  1.893E+04 -8.693E+04  1.052E-05  8.721E+06  1.899E+06 -1.942E+07
Notes: 1. All applied and SPC forces are transferred to
          the origin of the basic coordinate system,
          so that the applied and SPC loads can match.
       2. If spring elements and/or MPCs exist in the model,
          total applied loads may not match total SPC loads.
       3. If axisymmetric elements are present in the model,
          the total x-force and y-force and all the total
          moments are set to zero, according to principles
          of axisymmetric analysis.
       4. If periodic boundary conditions exist in the model,
In Hypermesh, I believe there are check boxes for outputs for same function.
OLOAD
SPCF
I just ran cases without the TEXT definitions in Input/Output section for OLOAD and SPCFORCE.
(1)  No output requests, whatever Optistruct elects to  output
  This produces no OLOAD or SPCFORCE output
(2) Output Requests for OLOAD = True, and SPCFORCE = solver defaults
  OLOAD =ALL shows in case control, SPCFORCE does not
  no applied force and reaction force summary table is generated
 i.e. SPCFORCE = solver defaults "negates" OLOAD=True
(3) Output Requests for OLOAD = no selection, SPCFORCE = Optistruct default
   SPCFORCE = OPTI
  This generates fem input "SPCFORCE = OPTI", but no OLOAD exists in fem file.
  both OLOAD and SPCFORCE are output to *.out by SPCFORCE=OPTI
Subcase:       1
Sum-App.  0.000E+00  0.000E+00 -4.448E+03 -3.107E+05  5.544E+05  0.000E+00
Sum-SPCF  9.364E-09  5.022E-10  4.448E+03  3.103E+05 -5.555E+05 -1.518E+03
4) Output Requests for OLOAD = no selection, SPCFORCE = ALL default
   SPCFORCE = ALL
  This generates fem input "SPCFORCE = ALL", but no OLOAD exists in fem file.
Hence, once SPCFORCE = OPTI or ALL, both applied and reaction force summary table is created in *.out
Best way to assure applied and reaction force without thinking which combination produces what,
simply insert OLOAD and SPCFORCE in Text Data for Loads and Contraints tab.   Works every time.
