Sign in to follow this
Roberto_
Simulation stopped - Hyperstudy/FluxMotor
Hello!,
I am doing some simulation in Hyperstudy from a FluxMotor Geometry and sometimes this error message appears (Execution fail), and stops the simulation. So I have to click "OK" and the the execution starts again.
I want to keep the PC simulating hypersutdy the whole night or a couple of hours without any stop of the silumation.
How can I disable this option / Text message?
Thank you in advance
Could you check if you have the option "Ignore failed evaluations" enabled in Specifications ? Also, can you tell me which versions are you using?
Hello Diana,
Thank you for the message.
I do have this option  "Ignore failed evaluations" enabled. And still I got the error message. (I think is because the error mesage comes from FluxMotor and not from Hyperstudy).
I am using Hyperstudy 2019.1 and FluxMotor 2019.1 professional version. (not student)
I also run the simulations with 1 multi execution. 32GB RAM and E5-1650@3,60GHz processor (and all the other softwares off to try to dont get error messages.
Hope you can help me with this.
Hi Roberto,
I've just seen your replies as I didn't receive notification of yours. Sorry for that.
The message Error 12 that stops your optimization in case of failed FluxMotor runs is due to the solver script.
Please go in Edit->Register solver script and set the FluxMotor solver script to point to FluxMotors.exe. Note that there are two .exe in the same directory, one FluxMotor.exe and another FluxMotors.exe with "s". You need to point to the one with "s".
Please let me know if it fix the issue with stopped optimization.
Kind regards,
Diana
Hello Diana,
Thank you for the reply messages.
So far the simulations are doing fine with the changes that you wrote me.
Thank you very much!.
