sravankumar
Modal Frequency response analysis
I guess the issue is with frequency range defined in Freq card and Tabled1.1st frequency of the assembly itself is 345hz and you are evaluating it for 100hz.
Actually the maximum speed of the motor is 3200rpm i.e., 53.33Hz . If we give the frequency range from 345Hz means it will be exceeding the maximum speed of the motor-pump assembly.
I am attaching the frequencies attained from Modal analysis.
Please do the needful.
