Magneto
Solving Problem - executeAlgo_c : Execution failed.
I have a problem solving a Flux 2d magneto static project (axissymmetric). The geometry check, mesh check and physical check shows no error. If I start solving the scenario this is written in the output window:
Begin of physical check ...
The final derivative of points defining the spline curve of material E235C must be equal to Mu0. The final relative permeability is equal to: 0.27947406883797
Please, verify the properties of the material: E235C
An electric circuit exists.
The active physical application does not take account of it.
End of physical check.
Automatic selection between local and distributed MUMPS...
Setting solver for presolving : Mumps Local
Setting solver for solving : Mumps Local
08:07:15    5776 sec. Start save ...
08:07:16    5777 sec. ... end save
Active formulation(s) :
MSAVEC : Axisymmetric magnetostatic vector potential formulation
Matrix system : non linear, real, symmetrical
08:07:16    5778 sec. Start solving problem ...
Step number 1
Value of parameter ELFORC_TRANSLATION_ANKER : None
Value of parameter LINPOS_TRANSLATION_ANKER : -.3E-03
Value of parameter VAR_STROM : 0.3
08:07:30    5791 sec. Start creating Dirichlet constraints at points...
08:07:30    5791 sec. ... end creating Dirichlet constraints at points.
08:07:30    5791 sec. Start save ...
08:07:32    5793 sec. ... end save
Mesh of compressible domains ...
08:08:07    5828 sec. Generating 2nd order elements is running
  Total number of nodes --> 551232
08:08:10    5831 sec. End generating 2nd order elements
  RAN1 unknowns are initialized to zero
08:08:16    5837 sec. Numbering of   551232 nodal values done.
08:08:16    5837 sec. Number of non zero matrix elements estimated to be    22055440
Non managed error which has stopped solving process
08:08:16    5837 sec. Start save ...
08:08:16    5837 sec. ... end save
08:08:16    5838 sec. Start reading ...
08:08:18    5839 sec. ... end reading
08:08:18    5839 sec. ... end solving problem.
executeAlgo_c : Execution failed.Failed execution
ERROR: Advanced
PBEPAV_3 => Error 49, no treated error type
PBCEVL_4 => failed
PBCEVL_3 => Failed
PBERES_3 => failed
FL5RE4   => Command not executed correctly
FL5ERS   => failed
FL5ERS_1 => failed
executeAlgo_c => failed
stdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.
Failed execution
    at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:170)
    at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method)
    at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:902)
    at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
    at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2169)
    at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83)
    at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:145)
    at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:347)
    at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2862)
    at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:2040)
    at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2159)
    at sun.reflect.GeneratedMethodAccessor380.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:206)
    at org.python.core.PyObject.__call__(PyObject.java:545)
    at org.python.core.PyObject.__call__(PyObject.java:551)
    at org.python.core.PyMethod.__call__(PyMethod.java:171)
    at pydb$py.executeMethod$205(pydb.py:1617)
    at pydb$py.call_function(pydb.py)
    at org.python.core.PyTableCode.call(PyTableCode.java:171)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:171)
    at org.python.core.PyFunction.__call__(PyFunction.java:434)
    at org.python.core.PyMethod.__call__(PyMethod.java:156)
    at pydb$py.__call__$172(pydb.py:1390)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:199)
    at org.python.core.PyFunction.__call__(PyFunction.java:482)
    at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
    at org.python.core.PyMethod.__call__(PyMethod.java:228)
    at org.python.core.PyMethod.__call__(PyMethod.java:223)
    at org.python.core.PyObject.invoke(PyObject.java:3715)
    at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
    at org.python.core.PyInstance.__call__(PyInstance.java:372)
    at org.python.core.PyObject.__call__(PyObject.java:424)
    at org.python.pycode._pyx237.f$0(<input>:1)
    at org.python.pycode._pyx237.call_function(<input>)
    at org.python.core.PyCode.call(PyCode.java:18)
    at org.python.core.Py.runCode(Py.java:1625)
    at org.python.core.Py.exec(Py.java:1669)
    at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
    at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:628)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:623)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:598)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:593)
    at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:638)
    at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:706)
    at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(CommandServerRequestsRouter.java:70)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(CommandServerRequestsOutputPlug.java:111)
    at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:692)
    at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
    at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93)
    at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
    at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
    at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
    at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
    at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
Someone an idea which can cause this error? I have build up nearly the same model last week, without any complication.
Maybe the problem come form the material that you use. When you do check physics, you get this warning:
Can you try to change the material and try to solve again the project.
If the problem persist, can you shar the Flux project.
Best regards.
sorry for the late response. In fact I solved the problem. First of all the fact, that the flux project can be solved in a static scenario, without a translation part, let me think that FLUX could have some issues with geometry identification and/or remeshing during the multistatic simulation.
The failure was caused by the Geometry (*.stp). For this analysis I modified an existing step-model in hypermesh. This leads to the fact, that in the exported new *.step file there where two "parts" in the part browser in hypermesh. When I modified the stepfile again by deleting one of the "parts" (not components!!!) Flux was able to solved the project.
To find this problem I was in contact with the Altair Flux support. He has no idea, why this caused such a problem. He forward the Support-Ticket to Hypermesh-Support. Maybe they have an idea.
Best regards.
Dear magneto,
I would like to get more details about the way you solved that file.
I have been simulating some files that didn't have solved because it jumped your same error and nobody could get solved it.
Best regards,
Andoni
