Sign in to follow this
Sukshith
Multi fluid interaction
1. I'm a beginner and recently started to work on Acusolve. I wanted to to get the flow trajectory (Streamline) of water coming out of a pipe into atmosphere (Medium- Air). So may I know whether this can be achieved using Acusolve, if yes, may I know the steps.
2. I have got the result for velocity and pressure at the outlet of pipe (flow through pipe problem), can the same values be used as inlet condition for the above problem or can both problems be combined?
Thank you.
This would be a two-phase simulation to get correct.  You can look through the tutorials through the Help system included in the installation.  Best bet is to work with your India Altair support team.
