ttttC
Importing geometry from Solidwork
Hi there. I have met a few problems with importing geometry from Solidwork.
As I am using the student version, I have imported solidwork file to CADFEKO in parasolid format.
I am looking for the inductance of the model so I have meshed the model and solved it to obtain the output file.
In the output file, it only shows the capacitance of the model:
Then, I have built a similar model using CADFEKO. But this time it shows the inductance of the model is 2.7uH.
The dimensions, model extent, voltage source, frequency used in both files are the same. I expected the results from both files would be similar.
At least both of them should have inductance shown in the output file.
Why there is such a big difference in the results? Is there anything I have done wrong?
spiral coil import from solidworks.cfs spiral coil import from solidworks.fek spiral coil import from solidworks.out spiral coil built using CADFEKO.cfx spiral coil built using CADFEKO.fek spiral coil built using CADFEKO.out spiral coil.x_t
Just looking at your two *.out files (you only attached only one model's cfx) I see 8700 triangles in the "solidworks" model while the cadfeko model only has wire segments, and then only 155.
The two meshes are way different from each other and therefore the results would be too.
In my understanding, more triangles means the solution is more accurate. Am I correct?
But I have built the model in real life and measured the inductance of the model. It is 2.68uH.
Does it mean my mesh for the "solidworks" model was incorrect?
Imported CAD can often have issues in the geometry causing poor meshing.
The triangle edges in the image below are not continuous and the edge port should cover the full circumference of the circular tube.
Is there any method for improving meshing?
If the import CAD is a wire, is there a method to allow CADFEKO to recognize it as a wire so I could perform meshing by using wire segments instead of triangles?
Or do you have any recommendations on improving the meshing for such model?
thanks a lot!
The spiral coil.x_t imported into CADFEKO comes in as a wire. This will mesh into wire segments.
I am not sure where you obtained the triangular mesh.
The import contains a wire loop and loop made from a cylinder.
I deleted the wire loop part.
For the disconnected faces, where the meshes don't align, select the two faces adjacent the disjoint, right-click to Copy (duplicate).
Then select the two copied faces and click on Stitch.
Then delete the two original faces from the original part.
Then Union the Stitch with the original part (part where the two faces were deleted).
I added an edge port as seen below and get 2.7 uH.
Some images.
May I ask how do you find those unaligned mesh? Or should I stitch all the faces together?
Do I need to delete the edges?
Moreover, I found that in POSTFEKO, the model will become cubical. Is this normal?
Sorry there is one more question.
I found these warnings in the output file:
WARNING 510: Imaginary part of the impedance is large thus the real part will be inaccurate
WARNING 509: Reactive power large thus real power is inaccurate
Do they have a big impact on the results? Is there anything I can do with them?
You must use double precision - enter the text in the search bar on the top right of cadfeko if you don't know where to enable this.
The mesh will look "cubical" if there are not enough triangles around the circumference of the tube.
You can also view the mesh in CADFEKO by disabling the Overlay and Model view icons and only enabling the Simulation mesh view icon on the Display options tab.
Connectivity can be viewed by clicking the Connectivity icon.
Thank you so much for such a fast respond.
I did set double precision but the warning still remained.
But at least I have got the inductance as 2.7uH. Thanks a lot!
But I have now met another problem. I am simulating the antenna which was fabricated on a pcb. So the cable is actually flat instead of cylindrical.
I have redrawn the whole antenna and try to simulate it. This time I have stitched all the faces and union them.
The triangle edges was set to 0.001.
However, I did not get the same result. I wonder if you have any idea.
antenna_14mm_flat.cfm antenna_14mm_flat.cfs antenna_14mm_flat.cfx antenna_14mm_flat.pre
