alpha
Error Radioss run wheel impact analysis
I try to follow the tutorial of Wheel Impact simulation (with Radioss) in Simlab learning center with SL 2019.3.
However, I cannot run and found the warning message in out file.
Then I import to HyperMesh and found that Spring elements are not assigned property properly.
I use HM to fix and can run.
But I want to know any setting upt is missed in video tutorial.
I think Altair should create PDF manual along with video. Only video is tough when SL keeps update and changing.
Hi.,
The Learning Center video is correct, but, there is an issue in SimLab 2019.3 on exporting spring as Radioss deck.
We fixed it, please let us know if you need patch for this fix.
Thanks Kamalraj,
If so, I will come back to use HyperMesh for temporary use.
I also try to run impact analysis with SHELL model but it sounds SL 2019.3 does not support.
