Hi Simon,
No, it is not possible to use Hypermesh to create the NLFE geometry. There are 18 different cross-sections possible in MotionView though, and you can also combine them to form a generic shape.
Best regards,
Felipe.
Hi Simon-
To answer your next question, the answer is no.  The motionsolve .xml commands have no relationship with traditional FE solver "Cards".  We have several macros for creating systems that utilize the most common use cases for NLFE.  Those are located on the vertical toolbar just to the left of the main GUI screen.  With these, you can create NLFE springs, NLFE stabilizer bars, and Belt-Pulley systems.
If you can give us more details about what you are trying to simulate, maybe we can suggest an appropriate approach.
Hi Chris, thanks for your interest.
The objective is to design a compliant mechanism by performing integrated structural and system level optimization (similar to OS-E: 4015 Optimization of MBD System Level Response). Flexible links are modeled with CMS flexbodies and hinges (small length flexural pivot) with NLFE. HM is preferred because it is easier to modify flexbody mesh and use Hypermorph to generate shape design variables, as opposed to Motionview where parameterization is done with hardpoint coordinates and there is no way to modify the mesh once it is imported.
This question is probably better posed to the HM forum, since that's the tool you'd prefer to use.  Note the the MBD capabilities within HM/OS are not widely used, and I don't think have complete coverage of entities.
Note, there are some methods, using Hyperstudy, and combining MotionView/MotionSolve and Optistruct to modify the flexbody per each run.  It requires some custom scripting, but we have some of our commercial customers using this approach.
Simon Križnik likes this
