EnDF
Job Launcher in Acusolve doesn't work
Hi everybody,
I have a problem with AcuSolve from Hyperworks. When I want to launch the Solver Job Launcher the "solver exec dir" is empty, but in another topic of this forum I saw that a possible solution is to insert the installation path of acusolve (as you can see in the image below).
I can't press the button Launch..
Instead, if I export the Solver Deck in AcuConsole ,resetting some data, the solution run.
What could be the problem?
thanks in advance
Dear acupro, thanks for your response
I have the academic version and I have this one in the image
joblauncher.png.9d00a93582f584c46dfedcbdea492e80.png.
Where is the acusolve job launcher?
The AcuSolve Job Launcher should be available in your Start > Program > Altair 2019> AcuSolve folder, like the screenshot below.
OR even using the Search  for Job Launcher on Windows 10 should reveal it.
EnDF likes this
My previous comment about 'Output Format' will not resolve anything.  That just means if you want to translate the output results to a format other than the native AcuSolve format, after the job is complete - so None is fine.
On 4/11/2020 at 4:39 PM, EnDF said:
Hi everybody,
thanks in advance
hi,
did you solve the problem?
for my experience, the reason is very simple.
the problem directory contains "space" in the path. you need to remove it.
no space are allowed in the folder path :D
