Sign in to follow this
przemyslaw.bolisega1
DOE EVALUATE ERROR FILE NOT FOUND
Hi guys,
i encountered some problems with my optimization in evaluate step in DOE 1. I run it for two models, one for compliance optimization and one for mass optimization. There are two separate folders and files do exist in folder. I don't understand what is the problem because the files are present. Hwsolver says that there is no problem and design is feasible. Any ideas?
1035 Message: Started run ( 1 ), model ( m_1 ), Execute ( pid = 14320 ).
1036 Message: Started  run ( 2 ), model ( m_1 ), Execute ( pid = 15272 ).
1037 Message: Started  run ( 3 ), model ( m_1 ), Execute ( pid = 15028 ).
1038 Message: Started  run ( 4 ), model ( m_1 ), Execute ( pid = 13628 ).
1039 Message: Finished run ( 1 ), model ( m_1 ), Execute ( pid = 14320 ).
1040 Message: Execute output (stdout) logged to file ( C:\Users\Ghost\Desktop\praca magisterska\CAD\obliczenia\rama3\s1\approaches\doe_1\run__00001\m_1\task__exe_stdout.txt ).
1041 Error  : Encountered    1 error using solver ( OptiStruct ( os ) )
              For more information see ( C:\Users\Ghost\Desktop\praca magisterska\CAD\obliczenia\rama3\s1\approaches\doe_1\run__00001\m_1\hwsolver.mesg ).
1042 Error  : The execute task is failed for model ( Model 1 ( m_1 ) ).
1043 Error  : Data source ( Element Stresses (2D & 3D) (2D) vonMises (Z1) ( ds_1 ) ) file not found ( C:\Users\Ghost\Desktop\praca magisterska\CAD\obliczenia\rama3\s1\approaches\doe_1\run__00001\m_1\rama3v5_s1.h3d ).
1044 Error  : Data source ( Objective - Value ( m_1_ds_1 ) ) file not found ( C:\Users\Ghost\Desktop\praca magisterska\CAD\obliczenia\rama3\s1\approaches\doe_1\run__00001\m_1\rama3v5.hgdata ).
1045 Error  : Data source ( Element Stresses (2D & 3D) (2D) vonMises (Z1) ( ds_1 ) ) file not found ( C:\Users\Ghost\Desktop\praca magisterska\CAD\obliczenia\rama3\s1\approaches\doe_1\run__00001\m_1\rama3v5_s1.h3d ).
1046 Warning: Cannot evaluate expression ( max(ds_1) ), Failed to extract ( Element Stresses (2D & 3D) (2D) vonMises (Z1) ( ds_1 ) )
              Check if all expressions, preference files, sources and other components are valid.
1047 Error  : Data source ( Objective - Value ( m_1_ds_1 ) ) file not found ( C:\Users\Ghost\Desktop\praca magisterska\CAD\obliczenia\rama3\s1\approaches\doe_1\run__00001\m_1\rama3v5.hgdata ).
1048 Warning: Cannot evaluate expression ( m_1_ds_1[0] ), Failed to extract ( Objective - Value ( m_1_ds_1 ) )
It seems there is an error with the solver execution and consequently with the responses extraction. Did you look at the error file for more information?
If you want you can export the archive (from menu File) and share it with me to check.
Kind regards,
Diana
