todotson@ncsu.edu
Importing into Flux PEEC from Altium
I'm trying to get started with Flux PEEC software. I'm interested in generating a gerber file in Altium and importing into Flux PEEC. However,  the importer keeps trying to add a .txt extension to the gerber files I try to import, which makes it unable to find my file. Is there any way to resolve this issue?
Sorry for this late answer.
With this information it is very difficult to know what is going wrong in the importing process.
Anyway, in the case of a format problem, you can always import a txt as a gerber file: you should select “all files” in the importing wizard.
Please, check also the gerber version of your files. Flux PEEC is qualified to import RS-274X, but problems could arise when using other versions.
Hope this helps.
Best regards.
Alejandro
