Aiko
Problems with import of Simulink Model in Activate
i'm pretty new to Activate and Altair Tools in general. In the past i just worked with Matlab / Simulink.
I am trying to import my Simulink model into Active, but i get multiple Errors in my Command Window. Below are some examples.
When i start the import i just get multiple errors like these and nothing else happens.
Is there a smooth way to find out what these error's mean and how i could fix them?
Thanks for your help.
Aiko
Quote
Error: error when executing 'C:\Users\kbrm\AppData\Local\Temp\Tempdir_6cKB6e\simport.bat': simport warning:
xml deep ast to xml explicit ast: dropping "Object" implementation section items
simport warning:
simport warning: xml deep ast to xml explicit ast: dropping unit
simport warning:
Xml_explicit_ast_to_mdl_ast: graphical binding for ident FunctionName was dropped
simport warning:
during block translation,
Implicit coercion of string ``3'' to an integer for ident "NumInputPorts"
simport warning:
"block Winkel\n, with type Scope",
Neither SampleTime, nor tsamp, nor sample_time was found
in the block arguments, using default ("Inherit" mode)
simport warning:
Xml_explicit_ast_to_mdl_ast: graphical binding for ident Inputs was dropped
Hi Aiko,
The list only shows warnings with not much importance. Please provide the complete output messages, if available.
Regards
Hi Aiko,
Unfortunately there are too many messages, and the list stops before an interesting error message appears.  I propose to split you model into several parts and import them separately.
Here are some common hints for a successful import (thanks to @Ramine and  @christiankeh)
  • Import of *.m files only works for parameters defined in this file, not for functions. To make this work as expected, you have to rename the file file extensions from*.m to *.oml and either ddd the path to the *.oml-files to the ModelInitialization script or open the corresponding path to the *.oml-files in th FileBrowser
  • Sometimes the importer can't recognize the correct output port size. In this case the row size of the output port has to be set manually. It happens e.g. if a Demux block is attached to the output port.
  • If an error message stating that the code within an OML block is too long, you can solve this, by “unchecking” the attribute “Atomic” in the superblock.
Regards
